Transmission trouble
Old Feb 24, 2011 | 06:20 PM
dmathis27's Avatar
dmathis27
Question Transmission trouble
I have a 96 dodge 1500 pickup v8 magnum 318 engine 2WD and i am having transmission trouble so I thought. I replaced it with another and still doing the same thing. I only have first and second gear and reverse want shift to third. I also replaces the TPS but that did not help at all. I can get to 30 MPH and thats it then it comes out of gear like its in neutral. Any Ideas for help. I am not thinking its a Trans problem since I have replace with another and it is still doing the same thing.
Old Feb 24, 2011 | 06:23 PM
Its an internal trans problem, why you got a second with the same problem is beyond me.
First thing I would do is drop the pan, change the fluid and filter, and take a long hard look at the pressure sensor, and solenoid.
Old Feb 24, 2011 | 06:38 PM
dmathis27's Avatar
dmathis27
Ok should I just ask for another Trans since I have a warrenty on it or is the sensors and soleniod a quick and cheap fix?
Old Feb 24, 2011 | 06:45 PM
bjr1a's Avatar
bjr1a
Disconnect the 8 pin connector near the rear cooling line.....then place gear selector in D posiition...Trans should be immediately in 3rd gear..If it is not in 3rd, its definetly internal.....
Old Feb 24, 2011 | 07:47 PM
dmathis27's Avatar
dmathis27
Thanks I will try that.
