Additional items while fixing Plenum
Old Feb 26, 2011 | 11:46 PM
romadramowner's Avatar
romadramowner
I got it from NAPA. How can I tell if it's junk? I just want to know the symtoms for my own edification.
Old Feb 26, 2011 | 11:49 PM
KSteng89's Avatar
KSteng89
Front O2 Sensor and gaskets.
Old Feb 26, 2011 | 11:55 PM
romadramowner
KSteng89,
Is the front O2 sensor the item directly to the right of the thermostat as you look at the engine?
Old Feb 27, 2011 | 12:05 AM
Excessive Oil consumption. Aftermarket valves don't have as tight of control on flow rates.... so, they tend to suck oil too.
KSteng89,
Sensors on the manifold by the thermo housing are engine coolant temp sensors. O2 sensors are in the exhaust. Pre-cat is the one right where the two down pipes come together at the cat. (unless you have california emissions.....)
Old Feb 27, 2011 | 12:20 AM
romadramowner
Thanks brother. I appreciate all the advice/inputs. I already replaced the exhaust O2 sensors last month so at least that's done. I will head to the dealer on Monday to get the PVC.
Old Feb 27, 2011 | 12:59 AM
KSteng89's Avatar
KSteng89
While you have the kegger out you can do the kegger mod and cut them runners down.
