2 Bar Map Sensor
Old Feb 27, 2011 | 02:40 PM
kuziwr's Avatar
kuziwr
Default 2 Bar Map Sensor
I was just reading up on the Hemifever website, and the tuner i was looking at said it supported a "2 bar Map sensor"
What good would this do?
Old Feb 27, 2011 | 02:42 PM
Unless you do forced induction, (turbo, or supercharger) you don't need it. Basically, all it is, is a map sensor that will read PRESSURE in the plenum.
Old Feb 27, 2011 | 02:45 PM
aim4squirrels's Avatar
aim4squirrels
Nothing unless you are running boost. 2 bar should be good for 30psi of boost, iirc.
The naturally aspirated never sees a boost condition, and the stock map sensor is made within a range to read to about 6psi of boost. If you run more than that, you need a map sensor that will reduce the signal so the PCM doesn't freak out seeing that high a pressure and can accurately deliver the correct amount of fuel.
Old Feb 27, 2011 | 03:14 PM
kuziwr's Avatar
kuziwr
sweet thanks, now i know
