O2S won't perform self-test?
Old Mar 4, 2011 | 01:23 PM
Smashed-And-RAM's Avatar
Smashed-And-RAM
Fuel System 1 Status: CL
STFT Bank 1: Range -1.56 to 5.47% mostly at 0.0%
LTFT Bank 1: Range -2.34 to 0.0% (-2.34% when I first started it, after idling for 1 minute, it kicked down to 0.)
Monitors:
MIL: OFF
Misfire Monitoring: Complete
Fuel System Monitoring: Complete
Comprehensive Component Monitoring: Complete
Catalyst Monitoring: Complete
Oxygen Sensor Monitoring: Not Complete
Oxygen Sensor Heater Monitoring: Complete
Calculated LOAD Value%: 5.49
Engine Coolant Temp*C: 86.00
Short Term Fuel Trim-Bank 1%: 5.47
Long Term Fuel Trim-Bank 1%: -2.34
Intake Manifold Absolute Pressure kPa: 34.00
Engine RPM: 913.75
Vehicle Speed Sensor km/h: 0.00
Ignition Timing Advance #1 Cylinderdeg: 4.00
Intake Air Temperature*C: 61.00
Absolute Throttle Position%: 11.76
Bank 1 - Sensor 1 V: 0.16
Bank 1 - Sensor 1%: 6.25
Bank 1 - Sensor 2V: 0.70
OBD Requirements: OBD
Auxilary Input Status: Off
Old Mar 4, 2011 | 02:47 PM
I wonder if O2 monitoring will ever be complete? I can't really find a lot of information on that..... probably in the diagnostic manual... which I have been unable to find online as well.
Old Mar 4, 2011 | 03:13 PM
Smashed-And-RAM
It's beginning to scare me. The dealer said they could fix it for $89.00, but that just seems ridiculous. The monitor should run it's self test without any coaxing from a computer. If it doesn't reset itself soon I will simply go outside, pull the battery, and turn on the head lights. I can't see how that's any different than resetting the code with my meter, but I guess I can try that next week if this doesn't change.
Any other ideas?
Old Mar 4, 2011 | 10:56 PM
JackJ's Avatar
JackJ
Have you looked at the wiring on the O2 sensors?, Also how long were you driving when you got this data, I had a TPS replaced on a Jeep and I had to drive a good 100 miles at temp to get it to complete the test. Also your temp is just a tit hair above what would be considered operating temp ~180, if you have a colder T-stat in it (stock is 195) you could try turning your AC on to see if you can warm it up a bit.
Most decent places will do a free diagnosis on vehicles take it to one of those and see what they say, I have done it many time when I was to lazy to research something or could not find the answer.
Old Mar 4, 2011 | 11:09 PM
Smashed-And-RAM
The temp goes up to 195°F after allowing it to idle a little longer, I had started it up a little while before I captured the data. I plan on looking at the wiring on the O2 sensor tomorrow, but wouldn't it give some kind of other issues if it wasn't correct? Only place I know of around here that does free estimates is Conrad's, and I wouldn't trust them with my father-in-law's truck, let alone my own.
BTW, I've been driving for about 200+ miles. City/Highway combined. Most were over 20-30 minute drives at a time.
