ok my ram is burning oil
Old Mar 2, 2011 | 05:28 PM
chaddbrockway's Avatar
chaddbrockway
Default ok my ram is burning oil
my 98 ram 5.2 burning oil i already changed the plenum gasket, and it only seems to be building up when idling. then on take off a nice size puff come out. my oil gauge drops at idle, and i was wondering, if my pump was going out could it be starving my pistons of oil making it burn?
Old Mar 2, 2011 | 06:15 PM
Replace the PCV valve with one from the dealer. Aftermarket units don't always have the correct flow rate.
Old Mar 2, 2011 | 06:25 PM
chaddbrockway
ya im waiting for it to get in the dealer had to order one for me. do you really think that could be causing the smoke issue seems a liitle to good to be true.
Old Mar 2, 2011 | 09:27 PM
May have valve seals going as well. If the truck is high mileage.... really wouldn't be that much of a surprise.
I have 167K on my truck, engine is pretty much original, aside from a plate, and some gaskets...... I don't get any smoke at startup 99% of the time. I DID have some serious oil burning issues with an aftermarket PCV though....
Old Mar 4, 2011 | 01:33 PM
chaddbrockway
update! changed over to oem pcv valve, still getting smoke, put new oil pressure sensor in it. it holds at around 30 psi at idle. i'm thinking leaking valve stem seal, any way of telling wich valve seal could be leaking? or should i just change them all?
Old Mar 4, 2011 | 02:45 PM
Change 'em all. They all live in the exact same environment, so, if one is going, you can bet the rest aren't far behind.
Old Mar 10, 2011 | 02:50 PM
chaddbrockway
Update: changed the valve steam seals in my ram. 7 out of 16 of them were split in half cant beleive how bad they were. oil burning is gone, and no more blue smoke yay..hope i'm done for a while.
Old Mar 10, 2011 | 04:20 PM
charlie1935's Avatar
charlie1935
Very good !! Some of old farts appreciate the update.
