Dodge ram 1996 5.9 ambient air temp
Old Mar 3, 2011 | 01:43 PM
Renegade3's Avatar
Renegade3
Default Dodge ram 1996 5.9 ambient air temp
Can anyone tell me where I can locate the ambient air temp sensor ? I have an error P0711 from my OBD2. Thanks for your help. A pic or detailed description would help me greatly as I need to replace it
Old Mar 3, 2011 | 03:09 PM
Old Dodge 1's Avatar
Old Dodge 1
Cool Here you go!!!!
Locate the ambient temperature sensor, on the underside of the hood near the hood latch striker
1.Disconnect and isolate the battery negative cable.
Fig.8 Ambient Temperature Sensor Remove/Install
2.Locate the ambient temperature sensor, on the underside of the hood near the hood latch striker.
3.Disconnect the wire harness connector from the ambient temperature sensor connector receptacle.
4.Remove the one screw that secures the ambient temperature sensor bracket to the inner hood reinforcement.
5.Remove the ambient temperature sensor from the inner hood reinforcement.
INSTALLATION
1.Position the ambient temperature sensor onto the inner hood reinforcement.
2.Install and tighten the one screw that secures the ambient temperature sensor bracket to the inner hood reinforcement. Tighten the screw to 5.6 Nm (50 in. lbs.) .
3.Reconnect the wire harness connector to the ambient temperature sensor connector receptacle.
4.Reconnect the battery negative cable.
Old Mar 18, 2011 | 06:05 PM
Renegade3's Avatar
Renegade3
cant find it on my 95 Ram
Old Mar 18, 2011 | 06:22 PM
lukeca's Avatar
lukeca
I don't know if this is where it supposed to be because on my 95 the ambient air sensor was actually missing, but I found the wiring for it dangling below the bumper closer to the driver side. I got a new sensor and mounted it a hole I found near that location. The wiring seemed to be bundled together with the wiring for the fog lights if that helps you find where I am talking about.
Old Mar 18, 2011 | 08:35 PM
aim4squirrels's Avatar
aim4squirrels
mine is behind the grill, it goes up into the air when you lift the hood. IIRC, somebody mentioned that on older model vehicles had it behind on of the front rad supports.
