How do i install a camshaft position sensor
Old Mar 3, 2011 | 09:50 PM
4x4SWAG's Avatar
4x4SWAG
Unhappy How do i install a camshaft position sensor
like the title says lol i need help
Old Mar 3, 2011 | 11:59 PM
Its under the distributor cap. Its a drag to get to...... cleverly concealed behind the engine, under the cowl....... Pull the cap off. Sensor is right there.
Old Mar 4, 2011 | 12:03 AM
dhvaughan's Avatar
dhvaughan
its what appears the be the bottom plate under the dist cap. its sort of a false bottom and looks like this...
some people place a big piece of plywood across the fenders and crawl up on it. i've not tried that yet, but will someday.
Old Mar 6, 2011 | 08:35 PM
aarons ram's Avatar
aarons ram
Funny thing about these, i can fix them with my eyes closed. I replace 4-5 of them. Stupid i know but i thought something was causng them to blow out, was out of state so could get to my echanic. Turned out to be the timing chain.
The easiest way i found was to remove the air cleaner, take a screwdriver undo the three(?) screws,take of the cap/rotor, reach down the sensor is just laying in there unplug, replace with new one. Just make sure you have it facing rightside up at the right angle, only lays one way(correctly)
Sorry i just had alot of problems with it.
Old Mar 6, 2011 | 10:25 PM
joeyd208's Avatar
joeyd208
i thought that was the CRANKshaft position sensor? i might be wrong? when i had to replace the camshaft position sensor it was in the back of the motor on the driverside and it was a pain in the *** it looked something like this and it was held on by two allen head bolts? but thats what i was told to replace and it took care of the problem i could be wrong but yeah thats all i was told
Old Mar 7, 2011 | 07:17 AM
dhvaughan's Avatar
dhvaughan
^the picture in Joey's post is the crankshaft position sensor, and installs where he said, in the bell housing.
Old Mar 7, 2011 | 08:34 PM
joeyd208's Avatar
joeyd208
yeah thats my fault i wasnt thinking clearly and mistaked the CAM for the CRANK so dont listen to me lol! but for future refrence if you have to replace it you will know what it looks like and where its located at sorry my fault...
Old Mar 8, 2011 | 01:19 AM
aarons ram's Avatar
aarons ram
I have replaced both lol needed the crank sen after my timing chain replacement. That was a major b****.
