problems with engine cylinder test
Old Mar 5, 2011 | 04:21 PM
chaddbrockway's Avatar
chaddbrockway
Default problems with engine cylinder test
i'm doing a compression test on my 98 5.2 ram. took all the plugs out unhooked coil wire, and fuel. hooked tester to cylinder 1 cranked it 5 times pressure built up, but left the tester rapidly. i did same thing on all the cylinders, and same result. is it a faulty gauge, or is there a major problem here?
Old Mar 5, 2011 | 05:42 PM
dhvaughan's Avatar
dhvaughan
the tester should hold the pressure reading until you push the release button to re-zero the gauge. sounds like a faulty tester.
Old Mar 5, 2011 | 08:10 PM
chaddbrockway
ya it was the tester. got new tester it read 155 psi accross the entire engine, with dry test it must be the valve guide seals that is burning the oil. thanks for the input.
Old Mar 5, 2011 | 08:27 PM
dhvaughan's Avatar
dhvaughan
155 is very good. congrats.
if you're losing oil and you've never fixed your plenum.... then that's likely the problem.
Old Mar 5, 2011 | 09:59 PM
chaddbrockway
ya i just did the plenum, and pcv valve, getting a little light blue smoke when the truck is idling.
Old Mar 5, 2011 | 10:00 PM
Get your PCV valve from the dealer. The aftermarket ones flow too much. (and burn oil.)
Old Mar 5, 2011 | 11:30 PM
chaddbrockway
ya i got one from the dealer put it in and still the puffs of smoke when idling.it's gotta be the valve seats it's the only thing left.that i can think of. i think i'm just going to sell the truck and go back to gmc or ford never had these kind of issues with any of those two this is crazy.125,000 miles and dealing with all this.
