Vibration at ~35 mph
Old Mar 5, 2011 | 11:35 PM
Jgoldy's Avatar
Jgoldy
Default Vibration at ~35 mph
There is a vibration in truck right around 35 mph that goes away by the time I get up to 40. It's a 2001 Ram 1500, 4WD. Any idea what the cause could be? Trying to save myself a trip to the dealer. It feels like its coming from the center front, right by the cupholders....
Thanks in advance
Old Mar 6, 2011 | 10:12 AM
Rotate your tires, see if the vibration moves with them. If it does, get 'em rebalanced.
Old Mar 7, 2011 | 09:42 PM
Jgoldy's Avatar
Jgoldy
Tires are brand new, less than 300 miles on them. Could it be that they were improperly balanced the first time?
Old Mar 7, 2011 | 11:04 PM
Smashed-And-RAM's Avatar
Smashed-And-RAM
Yes. If the tire balancing machine isn't properly calibrated then you could certainly be out of balance. If I remember it right you're supposed to balance the machine once a week, and make sure that it's zero'd out before every tire. Not to mention there is usually a limit of two weights that are put on any given tire.
Old Mar 7, 2011 | 11:57 PM
lukeca's Avatar
lukeca
Did the vibration start with the new tires? I've had a set of tires improperly balanced, just go back to the shop they will rebalance them for you if that is the problem
Old Mar 9, 2011 | 12:23 AM
dlamb's Avatar
dlamb
Check the tires for an odd ware pattern, could be balance and or alignment.
Old Mar 9, 2011 | 03:03 PM
Darrell67's Avatar
Darrell67
I had the same issue a couple years ago. The rear u-joint was on its way out.
Old Mar 9, 2011 | 03:14 PM
Randy_W's Avatar
Randy_W
Got a rear u-joint heading south, picked up the vibe at about 40-45, now I hear itwhen I slow down, better get it before it gets me!
Old Mar 9, 2011 | 04:55 PM
BamaRam97's Avatar
BamaRam97
Do a search for Death Wobble. It is caused by the track bar joint/fitting wearing out where it mounts to the frame. I installed a Luc's link to fix it. But check that the tires are balanced and that you haven't broken a belt in tire before you order anything.
Old Mar 9, 2011 | 05:58 PM
Also.... if you have aftermarket wheels, and they are lug-centered, make sure they were installed correctly. (although, I think if this were the problem, you would have a major shake, at any speed, that got worse the faster you went.)
