ABS and Brake light on
Old Mar 7, 2011 | 06:25 PM
JBULLFROG187's Avatar
JBULLFROG187
Default ABS and Brake light on
My ABS and Brake light are constantly on. Is this just the ABS sensor? If so, where the heck is it??
Old Mar 7, 2011 | 07:18 PM
Smashed-And-RAM's Avatar
Smashed-And-RAM
What year is the truck, 4x2 or 4x4, 4 wheel ABS or two wheel?
If it's a 1999 4x2 with 2 wheel ABS. The ABS sensor is on top of the rear differential. You'll see a few wires coming out of the top of the pumpkin. You've got two bolts that you've got to take off to pull it out, one holds the brake lines on, and the other bolt attaches the sensor to the differential, I really don't remember what the sizes of the bolts were, but I believe the top nut is a 13mm and the bottom is a 14mm. You'll need to use an open ended wrench to hold the bottom nut while you remove the top nut, otherwise you won't get it to come off. Once you get the top nut off all you've got to do is remove the bottom one, then you'll have to wiggle the sensor to get it out. I used a small, thin putty knife to wedge underneath it ... do not force it out, if you break it you'll be replacing the fluid in the differential since plastic pieces will drop into the diff.
Here's a link to what the part looks like. Even though if you buy it from O'Reilly it comes with the cage, extra length of wire, etc. You'll have to zip strip the wire to something so it doesn't get chewed up by the drive shaft.
http://www.oreillyauto.com/site/c/de...word=anti+lock
Old Mar 7, 2011 | 07:40 PM
WhtDually95's Avatar
WhtDually95
Do your brake lights work? I have found that its either the ABS light or Brake light. Both at once could be a blown fuse.
Old Mar 7, 2011 | 07:59 PM
VEETEN's Avatar
VEETEN
Both at once is a sensor most of the time. It was on mine.
Old Mar 7, 2011 | 08:31 PM
Smashed-And-RAM
The symptoms for my blown RWAL Sensor was ABS + Brake light on, no Speedometer/Cruise/Mileage.
Old Mar 7, 2011 | 08:38 PM
matty675's Avatar
matty675
Replace the RWAL sensor on top of the rear differential.
Old Mar 8, 2011 | 12:43 AM
outlaw93z's Avatar
outlaw93z
mine got screwed up by moisture after I got stuck in a deep mud bog. it caused the brakes to lock up pretty bad.
Old Mar 8, 2011 | 10:34 AM
pcfixerpro's Avatar
pcfixerpro
if you were closer, i'd offer to scan it for you to know for sure what the problem is.
Old Mar 8, 2011 | 11:58 AM
articsilber323's Avatar
articsilber323
i have a 99 2500 4X4 randomly turning the brake and abs light on but my spedo and mileage still work fine
it does it about about every 4th time i start the truck
any ideas?
