big project tool list
Old Mar 9, 2011 | 09:39 AM
dipsherry's Avatar
dipsherry
Default big project tool list
ok so here is a list of my parts i have...
new plenium plate and modded keggar
waterpump
double roller timing set
hs 1.7 rr
ball joints
inner and outer tie rods
pitman arm
idler arm
rear shoes , brake springs, drums
ok so i know i need a ball joint press. pitman arm puller, pickle fork, and a brake tool. that should sum up the brakes and suspension parts.
now as far as the motor i need a 3 jaw puller for the timing gears and a good torque wrench. i have a ft lb wrench but do i need a in lb also. thats about all i can think of. i have been reading up and thats where i got this list from just let me know if i need anything else
Old Mar 9, 2011 | 09:42 AM
redneck_ram's Avatar
redneck_ram
you need to add beer to the list, cant forget it. haha!! but in all seriousness. i think you got everything major. just a set of basic hand tools
Old Mar 9, 2011 | 09:53 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You need an inch lb. torque wrench also. And a large socket and puller for crank bolt and balancer. Don't forget large adjustable wrench or strap wrench or other means of removing the fan clutch.
Old Mar 9, 2011 | 09:58 AM
dipsherry's Avatar
dipsherry
i always keep a stock off beer around lol
Old Mar 9, 2011 | 10:00 AM
dipsherry's Avatar
dipsherry
no fan for me so that saves me a little time... but i do need a inch lb wrench to add to the list and i know this is gettin real specific but you wouldnt know roughly what size the crank bolt is...
Old Mar 9, 2011 | 10:05 AM
zman17's Avatar
zman17
1 1/4" or 32mm will work.
Old Mar 9, 2011 | 10:06 AM
Silver_Dodge's Avatar
Silver_Dodge
Some more for your list:
-tstat
-waterpump bypass hose
-injector o-rings (if you take the injectors out of the intake)
-Stuff to do an oil change and tune-up after the plenum install
-new radiator hoses (just a good time to replace them)
-New serp belt (again, just a good time to replace it if needed)
I know there is more, but I can't think of it all right now. I haven't had my morning coffee.
Old Mar 9, 2011 | 10:13 AM
zman17's Avatar
zman17
Assembly lube for the rockers would be a good idea too.
Old Mar 9, 2011 | 11:32 AM
Do the tune up with the intake off. Its a hell of a lot easier that way.....
Old Mar 9, 2011 | 12:26 PM
charlie1935's Avatar
charlie1935
WHAT? No hammer? LOL
