do you think this would be a fun truck ?
Old Mar 21, 2011 | 04:20 PM
  #41
lastrights's Avatar
lastrights
goty the build sheet for it today, anything that doesnt look good ? 5.55 is the same as my ram :/ does anti spin mean open rear ? 1 wheel peel ?
Sales Code: --- Description:
*V9 Cloth 40/20/40 Bench Seat
-AZ Agate
ADA Light Group
AGGP Sport Group
APAS Monotone Paint
A03P 5.2L ENG(ELF)/5SPD M/T TRANS(DDC)
BAUS 117 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKPP 10x2.5 Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CBVP Cloth Door Trim Panel w/Map Pocket
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CKEP Front Seat Area Carpet
CUDP Mini Overhead Console
DBBC All Manual Transmissions
DDC 5-Speed HD Manual Transmission
DMDP 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
ELF 5.2L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GNES Passenger Side Sun Visor w/Mirror
GRUP Left Manual Mirror
GSUP Right Manual Mirror
GTUS 5 X 7 Mirrors
GVAC All Vehicles W/O Power Mirrors
HAA Air Conditioning
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
KNRS STRIPE/BADGE/MOLDING/COLOR
KTRS STRIPE/BADGE/MOLDING/COLOR
LAPP Shift Indicator Warning Lamp
LBBP Courtesy Lamps
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LDAP Underhood Lamp
LMBS Halogen Headlamps
LNJ Fog Lamps
LPEP Cargo Lamp
LPSS CHMSL Lamp
MBAS Painted Front Bumper
MBDS Argent Rear Bumper
MDA Front License Plate Bracket
MFNP Body Color Grille
MHAS Black Windshield Moldings
MLAP Body Color Fascias
NAA Federal Emissions
NBKS EVAP Control System
NBN Northeastern States Tracking
NFB 22 Gallon Fuel Tank
PW7 Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RASS AM/FM Cassette Radio
RCDP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUA Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TS1P P235/75R15XL BSW All Season Tires
TZAP Goodyear Brand Tires
WJ1P 15X7.0 Aluminum 5-Spoke Wheels
XBSS Pickup Box
YAAS Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGCA 7 Additional Gallons of Gas
ZBKP Spring - Left Front
ZCUP Spring - Left Rear
ZPKP Spring - Right Front
ZRUP Spring - Right Rear
Z1D GVW/Payload Rating
1AAS U.S. Dealer Retail
143S Zone 43-Pittsburgh
2TBA Customer Preferred Package 2TB
25B Customer Preferred Package 25B
3VDA Customer Preferred Discount
6USS U.S. Specifications Label
639S Pennsylvania Ship to State Code
939S Pennsylvania Sold to State Code
Old Mar 21, 2011 | 04:30 PM
  #42
Mad_Scientist's Avatar
Mad_Scientist
Anti-spin is chrysler-speak for limited slip I believe.
  #43
redheadhunter21's Avatar
redheadhunter21
Pretty sure antispin is the limited slip differential, and its a manual so 3.55 gears wont be bad at all
Old Mar 21, 2011 | 05:11 PM
  #44
lane's Avatar
lane
3.55 wont be bad in that considering it's manual and lighter than your truck. Anti slip is a limited slip so 2 wheel peel.
Old Mar 21, 2011 | 07:23 PM
  #45
Hahns5.2's Avatar
Hahns5.2
Yes anti-spin is LSD. And 3.55s are good with a 5 speed. The 5 speed has a lower OD ratio compared to the auto and that Dak also has smaller tires than your Ram. It should be around 2200 rpm at 70 which is pretty ideal.
Old Mar 21, 2011 | 07:29 PM
  #46
atthewmartin114's Avatar
atthewmartin114
ok i have the 3.55 gears and i have NEVER and i mean NEVER had the rear end only spin one tire. and this is my 3rd dakota with the 3.55 gears. and even more so i have replaced about 4 rear ends because for some reason the 5.2 eats them with the manual (or maybe its smoking 35/12.50s in 4x4) but either way and as far as the anti-spin. its a crock of **** the rear end is a limited slip deffently add the attidive when you swich the rear end fluid because it will eat the rear end up if you dont.
Old Mar 21, 2011 | 07:42 PM
  #47
Randy_W's Avatar
Randy_W
I bought a new '94 Dakota RC, 4x4, a/t with 3.92's and a 5.2 with limited slip/posi/ anti spin/locker or whatever it was. That truck was a blast! It would smoke the tires from a 20 mph roll any time you wanted.
Old Mar 21, 2011 | 07:43 PM
  #48
lastrights's Avatar
lastrights
what additive do you use ? if i destroy it im going to do 3.92 since i wont have to do the front
Old Mar 21, 2011 | 08:00 PM
  #49
PurplDodge's Avatar
PurplDodge
LSD...What other additive do you need?
Do you think this would be a fun truck?
http://www.youtube.com/watch?v=JmRDi...eature=related
Old Mar 21, 2011 | 10:12 PM
  #50
RamSport97's Avatar
RamSport97
Sick!
