Truck is all done but. . .
No, didn't test the thermostat before putting it in. I have never had a bad thermostat. It's a bugger to get to. It's probably just air in the system, but don't know how to get it out. Should I fill the radiator all the way up to overflowing or what? I'm at a loss.
That does happen.
The engine shouldn't get that warm that fast- unless its dang near empty.
Leave the rad cap off, idle engine, pour in juice. Fill it to top, wait a few seconds and repeat. When it holds steady slightly rev engine, and do it some more.
Is your top hose under pressure at all?
That does happen.
I found a DIY on burping the coolant system. I'm going to follow these steps and see what happens. Wish me luck. I will update either way . . .
I installee a 180 stat when I did my plenum fix. I never see the temp gauge touch 200, it runs at 170 180 I have efans also. But as far as your truck I would just let it idle and rev it up a little. use a glove and grab the thermostat hose and see if its still stiff if so then its the t stat
Before I did my plenum fix with stock t stat I was running about 220 230. For some odd reason these trucks like to run hot
