Headlight Keeps Blowing
Old Mar 10, 2011 | 10:55 PM
southern13guy's Avatar
southern13guy
Default Headlight Keeps Blowing
My headlight just blew about 3 weeks ago. It was replaced before then a few years ago. I put in a direct replacement and it lasted about 2 or 3 weeks and blew again. I replaced it as well as the other one last night. They both got the same bulb put in. Tonight while driving, I saw that the same one blew again. That's 3 times within 3 weeks. Any idea what it could be? When it blows, all the glass is gone from the bulb and all that's left is the base.
This is on my 96 Ram 1500.
Old Mar 10, 2011 | 11:02 PM
Mad_Scientist's Avatar
Mad_Scientist
Most likely your headlight casing came unsealed, which allows water to get in (or condensation to build up)... touch cold water with a hot bulb and... you know the rest
Old Mar 10, 2011 | 11:10 PM
UnregisteredUser's Avatar
UnregisteredUser
Are you taking care to keep your fingers and everything else off of the glass envelope of the replacement lamps? If not, try that -- and if you touch the envelope with anything, wash it with alcohol and try again more carefully.
Old Mar 10, 2011 | 11:29 PM
Also check your grounds.... a bad ground will EAT headlights.
Old Mar 12, 2011 | 12:06 AM
bcertain's Avatar
bcertain
+1 on the water getting in your light housing. I had the same problem.
Old Mar 12, 2011 | 12:24 AM
dodgeman2289's Avatar
dodgeman2289
happens to my fog lights every time i put new bulbs in them.. cracked lenses!
Old Mar 15, 2011 | 06:59 PM
southern13guy
Well I'm going to agree that it's the water. Didn't think it was that bad till I looked at it and I had just over a half inch of water in it as well as condensation on the lens. Just ordered a new pair of headlights so hopefully that fixes it! Thanks
Old Mar 15, 2011 | 07:18 PM
dodgeram07's Avatar
dodgeram07
info on the 3" suspension lift
Old Mar 16, 2011 | 11:28 AM
southern13guy
Rear block. Lift coil, upper control arms, and shocks from Suspension Max and it was the worst experience I've ever had. Don't buy anything from that company! If I have to make a topic on how bad my experience was with them then I will. The lift looks good in the end, but it took 3 months to get the lift installed correctly.
Old Mar 16, 2011 | 12:49 PM
dodgeram07's Avatar
dodgeram07
well it looks real good,, thanks for the tip on Suspension Max
