is this all the bolt ons
Old 03-11-2011 | 02:27 PM
dipsherry's Avatar
dipsherry
Default is this all the bolt ons
ok so after this weekend i should have what i consider all the bolt on mods. heres the list let me know if there is anything else i can do to up the hp/tq
8mm wires
accel coil
msd 6al box
ngk plugs
brass cap and rotor
modded keggar
aps plate
1.7 h&s roller rockers
spectar intake
headers
off road y pipe
pacesetter cat back
e-fans
180 tstat
high volume water pump
underdrive pulleys
52mm throttle body
21 lb 4 hole injectors
i know i need to regear and get a tune from b&g cause i am a 94 obd1 sucks. but if there is anything else simple i can do let me know. and as far as trans goes i plan on letting it go till it shots the sh*t then just attempt the 5spd swap
Old 03-11-2011 | 02:29 PM
See if you can find a mopar performance PCM?
Old 03-11-2011 | 02:39 PM
BackwoodsRam's Avatar
BackwoodsRam
I maybe be wrong,but a wide band o2 sensor for the upgraded injectors i belive.
Old 03-11-2011 | 02:40 PM
dipsherry's Avatar
dipsherry
i found one but didnt jump on it cause i tow alot like every weekend with my truck and dont want to find out the repercussions of towing with the mopar pcm...
Old 03-11-2011 | 05:30 PM
merc225hp's Avatar
merc225hp
I used to tow a 7000lb 5th wheel using a mopar performance pcm, and had no ill effects on my truck what so ever. You just have to tow smart and use good gas.
Old 03-11-2011 | 05:38 PM
drewactual's Avatar
drewactual
lose the NGK plugs.. they're ping city for many of us.. good ol' champ coppers @ <$2ea are the ticket for me.. some swear by the autolite's, but it comes down to a copper plug..
Old 03-12-2011 | 09:01 AM
dipsherry's Avatar
dipsherry
thanks man i was wondering if anyone has ever towed with one... i have always used premium anyways not sure why just to make myself feel better. so that wont be much of a change
Old 03-12-2011 | 09:02 AM
dipsherry's Avatar
dipsherry
thats what i had been useing just figured i would give the ngk's a try looks like i wont thanks for the advice
Old 03-12-2011 | 09:38 AM
hercuram's Avatar
hercuram
I recomend doing something with your rearend the clutches in the trackloc tend to break! i whent threw 3 set before putting a powertrax lock rite locker in mine. Grant it i rolled the truck about 700mi after i rebuilt the rear end. (nothig to do with rearend) but needless to say it will be up for sale SOON! baicly just watch for peices in rear diff when changing fluid!! and keep that problem in mind man!
Old 03-12-2011 | 10:36 AM
99dodge318's Avatar
99dodge318
dont forget the double roller timing chain and tensioner since your redoing your water pump, and maybe a high volume oil pump just for safety!
Quick Reply: is this all the bolt ons
