Need some Help Please!
Old Mar 29, 2011 | 08:11 PM
PasionitGrandpa's Avatar
PasionitGrandpa
Hey there, just a quick update.
Well got my water pump changed, my son put the metal return tube in and broke the tab of where it mounts to the block, had to weld that back up, and while I had it tore down I went ahead with HeyYou's idea and put a new timing set in and today I finally got around to look at why the 4 wheel drive didn't work and sure enough the backside of the metal line where it bolts to the right side of the frame right in front of the catalytic converter had a hole in it, so I went to Advanced and got 2 6' 3/16 metal lines and 2moro I am going to make a new double line.
I absolutely hate bending metal lines, it is a pain in the you know what.
Thanks for all the advice, it is greatly appreciated...Kev
Old Mar 29, 2011 | 08:54 PM
Those are small enough, that you should be able to bend them by hand easily.
You are gonna like it when it's done.
