Starting Problem
Old Mar 15, 2011 | 01:24 PM
iamtrust44's Avatar
iamtrust44
Default Starting Problem
Hi
I have a 1999 Ram 1500,5.2 motor,4x4, it turns over but won't start. The gas gauge is not working and I am not getting fuel pressure. Could it be any other likely cause other than the fuel pump module. I just wanted to eliminate all other causes before accessing the fuel tank. I also checked the fuel pump relay and it is ok.
If I do have to access the pump is it easier to remove the box or drop the tank. Thank you for the help.
Chris
Old Mar 15, 2011 | 01:36 PM
How about this thread?
