Brake lights done work HELP!
Old Mar 15, 2011 | 10:33 PM
95gaser360's Avatar
95gaser360
Default Brake lights done work HELP!
95 ram 2500 4x4 5.9l. brake lights dont work. the turn signals work the hazards work the rear lights come on when you turn them on but they dont get brighter when you push the pedal and the brake light that is on the rear of the cab works any ideas?
Old Mar 16, 2011 | 12:42 AM
CraZyNOTRT's Avatar
CraZyNOTRT
did you check if the bulbs are blown? then check the voltage at the bulbs contact points, check wiring under the truck. start at the back and work your way up front.
Old Mar 16, 2011 | 01:16 AM
joeyd208's Avatar
joeyd208
mine had the same problem it was the brake sensor that gets relesed when you push on the pedal try replacing that it cost me 10 bucks and that took care of it for me
Old Mar 16, 2011 | 08:43 AM
95gaser360's Avatar
95gaser360
yes the bulbs are fine because they still light up when you turn your lights on but the back up lights do not work only the ones that are in the red part of the tailight come on but they do not get brighter when you hit the pedal like they should
Old Mar 16, 2011 | 09:05 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure the brake pedal switch isn't broke, loose or disconnected. It may still need to be replaced as suggested. But a visual inspection is a good place to start. Also trace and check the wiring at the rear,since the reverse lights don't work either.
Old Mar 16, 2011 | 09:58 AM
95gaser360's Avatar
95gaser360
the brake pedal swithch does work so it must be the wiring back then correct?
Old Mar 16, 2011 | 10:04 AM
zman17's Avatar
zman17
How do you know it works? Did you test it with a meter or something? You just have to go through everything. No one here can tell you what is wrong. All we can do is suggest where and what to look at.
Old Mar 16, 2011 | 10:29 AM
95gaser360's Avatar
95gaser360
the only reason i know that it works is that my dad was reading the wiring diagrams or whatever there called and he somehow know that its working and i trust him. he would fix it he just doesnt have the time and hes pushing me to fix all my problems myself
Old Mar 16, 2011 | 11:04 AM
Open up the steering column, and have a look at the wiring by the multifunction switch. I am going to guess that you have tilt steering?
Old Mar 16, 2011 | 11:21 AM
CraZyNOTRT's Avatar
CraZyNOTRT
Umm dont these trucks run dual filament bulbs hi\lo ? your running lights may still work, but if the Hi filament could be burnt out? do not assume any thing, as the saying goes its makes an @ss out of u and me.
you also stated that the break light on the cab works, so it has to be wiring or the bulbs because every thing is on the same circuit
