vacuum problems???
Old Mar 16, 2011 | 03:39 PM
mlcram2001's Avatar
mlcram2001
ok thank you. im not atrans person other than swappin them i dont know much about them. where is the gov. body at? inside?
thanks for the help
Old Mar 16, 2011 | 03:48 PM
Drop the pan, is toward the back of the trans. Basically, you want anything with wires going to it.
Old Mar 16, 2011 | 09:01 PM
mlcram2001's Avatar
mlcram2001
thank you. i know ido still have the original trans. should i buy all the sensors or just take the ones out of theold one? cuase the inly thing that was wrong with the old one was the front pump went out in it. do you think they would still be good or just get new ones? cause im on a very limited budget,im gettin ready to have a baby. like within days.
Old Mar 16, 2011 | 09:25 PM
zman17's Avatar
zman17
Retired Moderator - RIP
For now you can try using the old ones. You have to remove the Gov body to get to the TC/OD solenoid assembly. The other end of the harness comes out by removing a plate on the side of the valve body so you can get to the screw and slide the pigtail out. That plate has a spring under it(don't lose it). Use a small putty knife to hold the spring in place, when you go to reinstall that plate.
