View Poll Results: 3.92's or Harland Sharp 1.7 Roller Rockers
3.92 Gears
7
53.85%
6
46.15%
Voters: 13. You may not vote on this poll
Harland Sharp RR's or 3.92's
Old Mar 18, 2011 | 12:46 AM
  #21
RamSport97's Avatar
RamSport97
Very true, if I recall correctly isn't the O/D gear ratio around .69? I know for sure I can keep my foot out of it, that is what my scangauge2 is for.
3.55x.69= 2.45
3.92x.69= 2.70
I guess that isn't too big a difference there.
Thanks Drew
Old Mar 18, 2011 | 12:49 AM
  #22
drewactual's Avatar
drewactual
it's about the difference of carrying a full size spare tire or none at all, is all.
Old Mar 18, 2011 | 12:51 AM
  #23
RamSport97's Avatar
RamSport97
So will the performance difference between the 3.55 and 3.92 be fairly noticeable in 1st and 2nd? Enough to justify going through with it?
Old Mar 18, 2011 | 12:59 AM
  #24
drewactual's Avatar
drewactual
we're speaking strictly my opinion here, that needs to be said...
you will hardly notice the difference at highway speed. You will certainly notice the difference off the line.
If it were me- and, again, my opinion- I would do gears.. it will barely if at all effect your overall mileage, but it will do other important things that the rollers won't: make life easier on your tranny.. and we all know the trannies in these things need all the help they can get.
on the other hand, you can bolt the rr's on in a couple hours, and they can be had for around $350.. You'll be adding torque, which will get you off the line something like the gears will- but at the expense of adding the extra torque to your tranny.. see where I'm coming from?
Old Mar 18, 2011 | 01:04 AM
  #25
RamSport97's Avatar
RamSport97
I see, makes perfect sense. decisions.
Old Mar 18, 2011 | 01:09 AM
  #26
redheadhunter21's Avatar
redheadhunter21
On your truck I would say yes....your lightweight(for a truck)
My brother has a chevy yes very different but, he went from 3.42 to 3.73's and noticed a difference, had the rear end blow up and got stuck with 3.42's again and you really noticed the difference then.
Old Mar 18, 2011 | 10:57 AM
  #27
What size tires are on the truck now? And what size came stock?
Old Mar 18, 2011 | 12:27 PM
  #28
RamSport97's Avatar
RamSport97
I am running 275/60/17's (30"), I believe stock was 245/75/16 (30.5").
Old Mar 18, 2011 | 02:50 PM
  #29
either one will help you then. Or, you could be a REAL glutton for punishment, and do BOTH!
Old Mar 18, 2011 | 04:38 PM
  #30
merc225hp's Avatar
merc225hp
Gears, The 1.7's just don't make that much of a diff. How about headers or cam?
