Abs and Brake lights on clicking sound heard
Old Mar 20, 2011 | 04:17 AM
darkangel2001lv's Avatar
darkangel2001lv
Default Abs and Brake lights on clicking sound heard
have a 99 ram 2500, have had truck in the shop 6 times since i bought it last month, Abs and brake light are on, and clicking sound can be heard at low speeds until tires drown sound out. This clicking sound is heard when applying the brakes, while pressing gas pedal and also when foot is off both pedals and coasting.
Old Mar 20, 2011 | 09:48 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Has the sensor on top of the rear axle been replaced? Has the PCM been checked for any codes?
Old Mar 20, 2011 | 10:29 AM
darkangel2001lv
sensor has been replaced as well as the abs control mod. has been scanned but no codes
Old Mar 20, 2011 | 11:12 AM
Do you have RWAL? or 4WAL?
If the light is on, there should be a code.
Old Mar 20, 2011 | 07:00 PM
darkangel2001lv
4 Wheel drive, dealership is telling me there is no code
Old Mar 20, 2011 | 08:41 PM
VEETEN's Avatar
VEETEN
If the ABS and Brake light is on there has to be a code.
Is this dealership a dodge dealership?
You need someone with a DRBII scanner to read C-codes on a late second gen.
Since you have front ABS also has any work been done on the front end recently?
Ball joints, Universals, Hub bearings.....
Old Mar 21, 2011 | 11:57 AM
4 wheel drive, but, do you have four wheel antilock brakes? Have a look at the front axle, see if there is a sensor wire going to each hub. If not, you have RWAL only.
