has anyones 1.7 HS ???
Old Mar 22, 2011 | 08:54 PM
lastrights's Avatar
lastrights
Default has anyones 1.7 HS ???
has anyone ones HS came loose and needed tightning down ? im thinking mine may need done ? had them on for about 20,000 miles now ? i have a tisk tisk tisk noise when accerating.
maybe could it be the IAC making that noise being bad ?
i need too get this truck running good wanted to sell it but inspection killed me so going to keep it, not going to get the money i want for it.
also thinking of taking off the cherry bomb extreme and going to a glass pack or aeroturbine . need something thats si/so for a better sound than duel out.
last resort is im going to be buying new heads with new pushrods and spring. and then ill have the whole top end rebuilt.
rather not do all this , rather do it too the dakota since 4x4 arnt ment to go fast.
Old Mar 22, 2011 | 10:01 PM
aim4squirrels's Avatar
aim4squirrels
Check your header bolts.
Old Mar 23, 2011 | 12:41 PM
Hahns5.2's Avatar
Hahns5.2
They shouldn't come loose. I checked mine after about 20,000 miles when I swapped valve covers and they were fine. Sounds like an exhaust leak.
Old Mar 23, 2011 | 02:14 PM
Silver_Dodge's Avatar
Silver_Dodge
Ya, I checked mine at about 25k, and they were still right at spec.
Old Mar 23, 2011 | 02:17 PM
PurplDodge's Avatar
PurplDodge
If you suspect they're loose, remove the valve cover and check.
Old Mar 23, 2011 | 02:46 PM
Silver_Dodge
Ya, it is a real easy job to check them.
Old Mar 23, 2011 | 03:26 PM
Hahns5.2's Avatar
Hahns5.2
Also I highly recomend the Aero Turbine with a single exhaust. I didn't like it at all with dual 2.5" tailpipes but in a 3" single side exit it was fantastic.
Old Mar 23, 2011 | 04:01 PM
Silver_Dodge
Fantastic for sound or performance?
Old Mar 23, 2011 | 05:05 PM
Hahns5.2's Avatar
Hahns5.2
Sound. Performance was the same between both. The dual tailpipes sounded like a big fart.
Old Mar 23, 2011 | 07:48 PM
lastrights's Avatar
lastrights
ya im going to do something diffrent cheery bomb extreme been on there for 5 years now. def doing si/so weather it be the aeroturbine or a glass pack. but dual out is 2 1/4 on my extreme way to small ... didnt know much about my truck 5 years ago
how the drone having it exit before the tire ?
