ABS, Brake Light, and P0734
Old Mar 23, 2011 | 09:27 AM
MedicNathan's Avatar
MedicNathan
Default ABS, Brake Light, and P0734
So I have the ABS and brake lights on again with P0734. Had this problem a couple weeks ago and it was fixed by replacing the vehicle speed sensor and the ABS wheel speed sensor (on a 1997 their are two,from searching on here this was apparently the last year before they were combined). On the ABS sensor there were two options, a $17 option and a $40 sensor, do you think this could be caused by having bought the wrong one? Or is there a problem elsewhere in the system that could be causing the sensors to short out?
Old Mar 23, 2011 | 09:37 AM
BamaRam97's Avatar
BamaRam97
My ABS and Brake lights were on. I replaced the ABS sensor on the top of the rear diff and that did nothing. I then replaced my blown up wheel cylinders and adjusted my brakes and the light went off. Check those rear brakes and see if anything has run a muck.
Old Mar 23, 2011 | 10:08 AM
MedicNathan
I'll check them out this weekend. I am guessing the speed sensor with the CEL though.
Old Mar 23, 2011 | 10:25 AM
BamaRam97's Avatar
BamaRam97
Maybe so. I've been told by a couple much smarter guys on here that our trucks don't like many brand sensors other than OEM and some NGK/NKT. That being said, the ABS Sensor I put on was a NAPA brand.
Old Mar 23, 2011 | 10:22 PM
MedicNathan
so for ****s and giggles i cleared the CEL, and everything is now normal. Any ideas on what would cause an intermittent problem like this?
Old Mar 24, 2011 | 06:11 AM
95RAM360's Avatar
95RAM360
my abs light is on cuz my rear brakes are worn to nothing....
and if you had no speedo as well, then it would be the speed sensor in the transfer case....and make sure you put the punched numbers in the right direction......i didnt do this and wasted $40 bucks on a sensor....
Old Mar 24, 2011 | 07:21 AM
MedicNathan
Replaced that one already. I did the same thing with the punched numbers, but I checked my repair manual before going back to carquest
