tires lock up with 10% brake pressure HELP!!!!
Old Feb 24, 2011 | 08:17 AM
95gaser360's Avatar
95gaser360
Default tires lock up with 10% brake pressure HELP!!!!
i took the truck up the road the last night and the brake lights were on and when i hit the brakes with about 10% pressure they locked up and the abs didnt work. i dont care so much about the abs problem but i would like to be able to stop without skidding everytime so if anyone has any ideas it would be greatly appreciated!
Old Feb 24, 2011 | 11:14 AM
Truedge's Avatar
Truedge
I am gonna guess that something has come loose in you rear drum on one side or the other. Does one side lock up or both?
Old Feb 24, 2011 | 02:51 PM
Sheriff420's Avatar
Sheriff420
That or a leaking wheel cylinder.
On of my wheel cylinders went out one time and the first stop of the day (in gravel) made me skid for a couple feet.
A friend of mine used to have an old ford and his would skid to a stop on pavement when both of his wheel cylinders blew.
Old Feb 24, 2011 | 07:31 PM
thetypezero's Avatar
thetypezero
I had the same problem a while back, Replaced a bunch of stuff trying to find out what it was. long story short it ended up being a bad caliper. *shrugs*
Old Feb 24, 2011 | 08:15 PM
JackJ's Avatar
JackJ
**** I wish I could stop like that while standing on the break, I have had ****ty pressure ever since I bought my truck and no amount of bleeding has fixed it.
Old Feb 26, 2011 | 09:38 AM
Echosider's Avatar
Echosider
A leaking axle seal will cause this too. Mine did it last year, I fixed it and now it's starting to do it again. I can smell my gear oil burn a little back there too. Give a sniff or two at your rear wheels. Especially after braking a few times. You'll notice it if it's there. Believe me.
Old Feb 26, 2011 | 09:41 AM
Sheriff420's Avatar
Sheriff420
If it smells like a dog turd then it's gear oil.
But believe it or not, gear oil has nothing on GM supercharger oil. That's some nasty stuff.
Old Feb 26, 2011 | 12:44 PM
94Beater's Avatar
94Beater
which tires lock up?
Front? Back? Left? or Right or all of them.
If individual wheels lock up then check brake components on this wheel.
If all of them lock up it could be a proportioning valve next to your master cylinder.
Old Mar 21, 2011 | 08:15 PM
codyayrton's Avatar
codyayrton
I'm having the same problem with my right rear. It is worse in cold and wet conditions. I noticed an oil spray on the inside of the wheel. Took the drum off and everything was saturated. I have yet to determine the source of the leak. I think it is from the axle as it does not look or smell like brake fluid. After ruling out the brake cylinder, I will be looking for the leaky axle seal.
Old Mar 24, 2011 | 08:02 AM
95gaser360's Avatar
95gaser360
i just took the rear wheeles off and sprayed it down with brake cleaner and took sand paper to drums and pads threw it back on and has been fine ever since
