i changed my alternator
i replaced my altenator as it failed the altenator test both with my own meter and the shop altenator test, once i installed the new one it ran great at 14.01 right on the mark, however i gave it some gas and the volts spiked up to 17 something it only did so for a few minutes and now its running fine again. is this something i should be worried about or was it just the computer needing a few minutes to re regulate the new altenator?
That's worrisome but will be difficult to diagnose as long as the symptom stays hidden.
In a nutshell, the regulator switches the ground of the field winding on and off to make the alternator switch between providing current and not providing current. It switches on when measured B+ is 0.5V below the target (13.7V) and switches off when B+ reaches 0.5V over the target (14.7V). So if you saw 17V the regulator failed to interrupt field winding current, which indicates a problem.
Most likely, because it went away on its own, it's a flaky connection somewhere. Recheck the small wires leading from the alternator to the PCM carefully, and clean the contact surfaces of the connector. A bit of dielectric grease is a good idea, as it'll keep corrosion from forming to bite you later.
thanks alot for the explanation on that, i didnt know thats how it worked, ill recheck the connections in a few days here. my old altenator would hold at about 14.6-7 this one stays right at 14.01
had a chevy bought a yellow top optima batt and reman alt , changed em both out and the reman alt cooked the optima battery gell was seeping out the top of the battery , had parts store check the alt and it pegged thier meter off the charts ,guy said he never seen anything like it, they gave me new battery and a "new" alt in replacement, just a thought but im sure your good
