4x4 camber problem
mine was 1 degree out, the moog joint will adjust to 1 1/2 degree + or - i believe...and when it was in the dealer it was on their alignment rack. cost me $65 just to have them check it...they said the only way to fix was straighten...
for what its worth, i'd get a second opinion from another alignment shop.
Sweet
Glad to see my stock front suspension still holding up at 125k. Had my last alignment done two years ago. Everything was good this time except my left toe was quite a bit off (.16) and my "steer ahead" was off.
So which is it? Doesnt affect camber or it does minuscle amount lol? Flipflopping after reading the link in the other thread lol. IT WILL AFFECT CAMBER ENOUGH TO NOTICE A TILT IN OR OUT IF NOT DONE CORRECT.
Technically it does(you are correct there, I'm wrong)feel better? But next to nothing, especially regarding this thread and whether or not you can see it. You could turn the axle upside down and not see it. And I've provided that link numerous time's and did not need your post to point it out.
