slight rattle noise at low idle
Old Mar 26, 2011 | 12:00 AM
TBI IRRIGATION's Avatar
TBI IRRIGATION
Default slight rattle noise at low idle
Hi, my 2001 2500 5.9 makes this slight rattle/vibration from the rear-left ish side of the truck when i take off gently. It only happens when i am in gear. (new auto tranny installed last month) the noise is only there until i reach about 20km an hour, then the truck is rides smooth. My drive shaft u-joints seem fine, no play at all. All my fluids are clean and at correct levels.
any help in diagnosing this would be much appreciated
Todd
Old Mar 26, 2011 | 12:06 AM
TryMeImHard's Avatar
TryMeImHard
Did you check all the hangers on exhaust?? Might be a heat shield, those do rattle when they get rotted out.
Old Mar 26, 2011 | 12:12 AM
TBI IRRIGATION
I will check em tomorrow in the day light. The thought crossed my mind it might be something Exhausty, will let you know
Old Mar 26, 2011 | 12:28 AM
TryMeImHard
well is it like a buzzing type of rattle?
Old Mar 26, 2011 | 01:41 AM
thetypezero's Avatar
thetypezero
Make sure the bolts on your leafs are tight? And in place? Or maybe your drums are catching on that one side?
Old Mar 26, 2011 | 09:03 AM
jrp267's Avatar
jrp267
could be the cat guts rattling around.
Old Mar 26, 2011 | 03:26 PM
ghost4321's Avatar
ghost4321
Or the muffler for that matter. Crawl under there and bang on 'em.
Old Mar 27, 2011 | 01:57 PM
TBI IRRIGATION
Thanks very much boys. It was indeed my muffler. Il
