98 ram
Old Mar 26, 2011 | 11:20 AM
dan64779's Avatar
dan64779
Cool 98 ram
hi my name is Dan and i have a 98 ram 1500 ex cab. it has the 5.9 in it.
my ram has a rough idle when its at an idle after i start or at a stop sign. i did replace the plugs, wires, cap and rotor, plus fuel injector cleaner every 3000 mile. can anyone give me any more ideas?
Old Mar 26, 2011 | 11:51 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Mar 26, 2011 | 12:53 PM
Check the Plenum.
How did your old plugs look?
Old Mar 26, 2011 | 12:56 PM
jasonw's Avatar
jasonw
Site Moderator
If the plugs look good, I'd check the IAC or TPS next. Both easy to do, relatively cheap replacements.
Old Mar 26, 2011 | 04:23 PM
dan64779's Avatar
dan64779
the plugs looked decent. i ill have to try what you said. i was thinking its out of time a little bit or 1 of the injectors my be bad. im not sure if those would make it have a rough idle or not. i have a snapon 2500 scanner that i put on the truck and the scanner doesnt show any codes.
Old Mar 26, 2011 | 05:53 PM
If it idles rough after its been running a few minutes, probably the pre-cat O2. If it runs rough ALL the time..... need to check the plenum.
Old Mar 29, 2011 | 10:05 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
