99 Dodge Ram 2500 Tranny
Old Mar 26, 2011 | 04:29 PM
rlepage28's Avatar
rlepage28
Default 99 Dodge Ram 2500 Tranny
So i bought a 99 dodge ram 2500 4x4 today. There is no reverse in the truck. My question is if you stand out side the truck and pull it into reverse you can hear it click like it wants to engage but it does not engage. Any ideas on what this could be or how to fix it. All other gears work great
Old Mar 26, 2011 | 05:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
NO REVERSE (D RANGES
OK)
1. Gearshift Linkage/Cable
Mis-adjusted/Damaged.
1. Repair or replace linkage parts as
needed.
2. Park Sprag Sticking. 2. Replace overdrive annulus gear.
3. Rear Band Mis-adjusted/Worn. 3. Adjust band; replace.
4. Valve Body Malfunction. 4. Remove and service valve body. Replace
valve body if any valves or valve bores are
worn or damaged.
5. Rear Servo Malfunction. 5. Remove and disassemble transmission.
Replace worn/damaged servo parts as
necessary.
6. Direct Clutch in Overdrive Worn. 6. Disassemble overdrive. Replace worn or
damaged parts.
7. Front Clutch Burnt. 7. Remove and disassemble transmission.
Replace worn, damaged clutch parts as
required.
Old Mar 27, 2011 | 10:36 AM
rlepage28's Avatar
rlepage28
Ok so is there a way to tell any of that. These are the symptons so far. and its an auto. Standing outside the truck and pulling it into reverse. It makes a clickin noise like wants to engage but doesnt. No reverse lights come on. Sometime they do when your half way in between reverse and park. Driving down the rd and puttin into first does not make the engine brake come on it just keeps going like i never did anything. Any ideas would be great thank you
Old Mar 27, 2011 | 10:38 AM
Start with a fluid/filter change, and adjusting the bands. While the pan is off, look for stuff that shouldn't be in there.......
Old Mar 27, 2011 | 03:16 PM
Smashed-And-RAM's Avatar
Smashed-And-RAM
Sounds like the linkage cable. Does it seem to go into drive in a weird position?
Old Mar 29, 2011 | 09:46 AM
rlepage28's Avatar
rlepage28
Ok this seems to be the problem now. The fluid was black but not burnt. I went to tightin the rear band but the screw just keep going in and never getting tight idk if that is right or not. Like I had to take the nut off all the way and the adjusting screw just kept going in never really gettin tight. Not sure what that could mean or if that is right. So I just put it back where it was in the first place and put all back together. Any help would be great thanks
Old Mar 29, 2011 | 09:48 AM
Did you drop the pan? My guess is, something fell out of place.
Old Mar 29, 2011 | 12:54 PM
rlepage28's Avatar
rlepage28
ya that was the rear band it happined on. all forward gears work great with no problems at all. i have no reverse and no low gear. like if i am at 3000 rpm and drop to first truck just keeps going like i never did anything, when it should slow the truck down.
Old Mar 29, 2011 | 12:56 PM
Ya lost me. Did you drop the pan?
Sounds like something fell out to me. Band anchors are pretty good at that...... and would explain a lot.
Old Mar 29, 2011 | 12:57 PM
rlepage28's Avatar
rlepage28
and yes i dropped the pan. didnt seem to find anything not suddpose to be in there. did find alot of lil tiny shavings maybe on the metal o ring in the transmission pan. they were very fine almost like sludge. what ever it was. it was black but could kinda see metal in it.
