Question about crankshaft position sensor
Old Mar 29, 2011 | 12:15 AM
slayer45065's Avatar
slayer45065
Default Question about crankshaft position sensor
I have a 2001 ram 2500 with the 5.9. About a month ago I went blasting through a puddle and the truck started bucking and backfiring so I did the first thing that came to mind cap, rotor, wires. After that she was running good, then I went through another puddle. Not only bucking but actually stalled out. I ended up getting a p1392. But as soon as she dried out was fine. I checked the ckp and the wires were all cracked and corroded so I went to advanced and picked one up. Ran ok for about 20 min then started missing and threw the code again. I brought it back and got another one, samething. Got my $ back and went to napa, Still missing. Is there a special way to install this thing? Am I supposed to shim it? I know its the sensor cause it ran fine with the original provided it was dry. I just dont get it.
Thanks
Old Mar 29, 2011 | 12:21 AM
97Rampowerhouse's Avatar
97Rampowerhouse
Thanks
no special way sounds like you still have water on the spark plugs
Old Mar 29, 2011 | 12:24 AM
slayer45065
No water, shes been dry for a good three weeks now.
Old Mar 29, 2011 | 12:28 AM
97Rampowerhouse
coils dry also?
Old Mar 29, 2011 | 12:33 AM
slayer45065
She's dry. Im about to go to a junk yard clip a harness and splice it to the old sensor just to test. I dont really know what else to do.
Old Mar 29, 2011 | 12:37 AM
97Rampowerhouse
let me ask this do you have a aftermarket air cleaner on your truck? If so is your weather stripping intact? Has it been raining where you are? I know some guys who have aftermarket aircleaners and weather stripping is bad and water gets down in the throttle body. Sorry for all the questions just trying to help figure it out.
Old Mar 29, 2011 | 12:43 AM
slayer45065
Stock air cleaner. I dont think its rained in atleast a week. No need to been sorry, Im glad someones trying to help
Old Mar 29, 2011 | 12:49 AM
97Rampowerhouse
Well HELL! So the truck starts fine right? Idles fine? Just starts back firing when you hit the gas.
Old Mar 29, 2011 | 12:56 AM
slayer45065
Not backfiring right now. But you can hear it popping through the exhaust. Like its not firing on one cylinder but I'm not getting a code for a missfire.
Old Mar 29, 2011 | 01:01 AM
97Rampowerhouse
PLENUM GASKET IS BLOWN! Look down the throttle body with flash light with butterflies open, if there is oil residue on the bottom plenum needs to be fixed.
