'97 360 #6 misfire
Old Mar 29, 2011 | 04:38 AM
mfdfire29's Avatar
mfdfire29
Default '97 360 #6 misfire
my '97 ram 360 has a #6 misfire even after a tune up and replacing the spark plug twice. It lugs mostly at low rpm's in forth gear, runs smoother at high rpm but kinda low on power with some random backfire.first spark plug was sooty with a white tip. any thoughts??
Old Mar 29, 2011 | 10:17 AM
Do a compression or cylinder leakdown test.
Old Mar 29, 2011 | 10:26 PM
mfdfire29's Avatar
mfdfire29
i did a compression test and it held 115pounds. i checked spark its good.
Old Mar 29, 2011 | 10:30 PM
Do you get good spark at the spark plug end of that wire? If so, swap the injectors on 6 and 8, see if the miss migrates.
