Shackle flip complete
Old Mar 31, 2011 | 10:13 PM
  #41
Originally Posted by olyelr
Jeesh, just quickly running numbers through my head as I read through your post I knew you were way off. Next time you should probably get the calculator out. Pff
Um.... I did use the calculator..... I uh, just... erm..... divided by the wrong term...........
OOps.
  #42
EndIsNear's Avatar
EndIsNear
I read about that. Thats why I said it might need a degree or two of difference. Ill just dish out the $40, get the kit, and fix the problem. It does raise the rear up another inch though. I dont know how easy that will be to dial in...anyways, thanks
Old Mar 31, 2011 | 10:27 PM
  #43
Originally Posted by tweeker909
Its not on the same arc. Flip only lifts the rear shackle not both front and rear therefore its no longer on the same plain as factory. Raise just the rear shackle and the pinion raises up few degree's. I tell you what go over to ps or pirate or call a local off-road shop see what they have to say about it...Hell just google shackle flip and every one of those forums will tell you to install a zero.
The front spring mount is the pivot point. That didn't change.
Old Apr 1, 2011 | 12:33 AM
  #44
dodgeram07's Avatar
dodgeram07
damn looks good
always move the front spring mount down,, but there you may need to drop the tank to get bolts in,,,nnnnnnnaaaaaa that dont sound fun
