gearing
Old Mar 30, 2011 | 11:12 PM
biff10's Avatar
biff10
Default gearing
I have a 95 4x4 2500 with a v-10. Going down the freeway it seems really wound up. It runs around 2800 rpm. just running 265/70/17 tires so that wouldnt be a big deal. Any ideas????
Old Mar 30, 2011 | 11:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Is OD working?
Old Mar 30, 2011 | 11:30 PM
Sure doesn't sound that way......
Check engine lite on?
Old Mar 31, 2011 | 06:56 AM
newman1367's Avatar
newman1367
It's not kicking into overdrive. I would start by checking the button in the dash that locks out overdrive. It's been about 8 years since I drove my 95 so I can't recall if it's a momentary switch or not.
Old Mar 31, 2011 | 08:51 PM
biff10's Avatar
biff10
The switch doesnt light up for the OD off.
Old Mar 31, 2011 | 08:57 PM
zman17's Avatar
zman17
Try this and see what if any codes show up. http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Old Apr 5, 2011 | 07:19 PM
biff10's Avatar
biff10
The switch does light up for the OD off. It still does nothing. I have a book but it doesnt go that into detail about the overdrive switch. Any other ideas???
Old Apr 5, 2011 | 07:35 PM
zman17's Avatar
zman17
Well did you check for codes?
Old Apr 5, 2011 | 07:56 PM
biff10's Avatar
biff10
Only an o2 sensor code. I think it was 21. I saw on another site it could be the OD switch in the tranny????
Old Apr 5, 2011 | 08:08 PM
zman17's Avatar
zman17
It could very well be the OD solenoid. One would think there would be a code. I'm not sure how you could test it. The RH tranny is different than the RE. Any info or links I could provide are for the RE and most likely won't help . However, You should trace the wires and check the plug on the tranny and swap the trans relay with another one. Relays are under hood in the PDC(black box by battery)
