3 inch suspension lift and 3 inch body
Old Mar 31, 2011 | 02:41 PM
98violet's Avatar
98violet
Default 3 inch suspension lift and 3 inch body
I have a 3 inch suspension lift on my truck now and 305 series tire. If i add a 3 inch body lift can i fit 37's on it?
Old Mar 31, 2011 | 02:44 PM
Probably. With a bit of rub here and there.
Old Apr 1, 2011 | 12:43 AM
dodgeram07's Avatar
dodgeram07
ya rub here and there,,,,,,,, if you have stock c-arm and a 3in lift thats not going to help not rubing,,,
35's u be fine
Old Apr 1, 2011 | 12:57 AM
Relex's Avatar
Relex
My friend has 5" on his truck and he is running 37x12.50's and he has a little rub.
Old Apr 1, 2011 | 07:34 AM
olyelr's Avatar
olyelr
Since purpl ain't seen a pic of olyelr in a while...
Here is a 3" suspension and 3" body with 35's. Only rub was on the control arms due to using the stock wheels with lots of backspacing...
What size wheels are you using? If they are 10" wide I am almost positive you will get rubbing against the back portion of the front fenders when turning/flexing. If you get a properly backspaced 8" wide wheel, you may just clear everything (including the control arms).
Old Apr 1, 2011 | 11:13 AM
dipsherry's Avatar
dipsherry
olyer your old truck is my dream truck yellow sport off road package...everytime you post pics i drool... Thanks you can keep on posting
Old Apr 1, 2011 | 03:33 PM
98violet's Avatar
98violet
This is my truck with 3" suspension an 305 tires
Old Apr 2, 2011 | 06:34 AM
olyelr's Avatar
olyelr
So are those wheels 16x10's?
Old Apr 3, 2011 | 07:26 PM
98violet's Avatar
98violet
yea there 16x10's
Old Apr 4, 2011 | 11:17 AM
green97's Avatar
green97
What can you do to not rub on the control arms because I have that problem on mine...
