vacum line
Old Mar 31, 2011 | 06:42 PM
Bam Bam's Avatar
Bam Bam
Unhappy vacum line
Where does the big vacum line that comes out of the transfer case go. I was under my truck today and found it hanging down near the cat. It is rubber up to there and then it is attached to a metal line and that is where it is broke there is also a tab on it with a bolt hole through it right where its broke. Its a 1996 1500 with the 360. I am grateful for any help
Old Mar 31, 2011 | 06:44 PM
95RAM360's Avatar
95RAM360
is it the 4 prong connector? does it have four holes at the end? if so, it goes about midway on the top on drivers side.....you can see it if you pull up your shift boot.
Old Mar 31, 2011 | 07:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Post a pic if you can.
Old Mar 31, 2011 | 08:20 PM
If its just a single line, its a vent line. Goes up to a clip, or some such, where the dipstick tube for the auto trans bolts to the bellhousing.
