Need Help With Drop Kit
Old Mar 31, 2011 | 10:59 PM
281-318magnum's Avatar
281-318magnum
Default Need Help With Drop Kit
I'm wanting to get a 4"/6" drop kit for my truck next week but i want to run 22" srt rims and don't want them to rub. Anyone running this set up. any suggestion would be helpful. Thanks
Old Mar 31, 2011 | 11:35 PM
97tn4x4's Avatar
97tn4x4
You "should" be ok just be sure to check the backspacing of the wheels. Post up the backspacing and I'm sure we can determine if they'll fit. That will be a super clean truck when you get it done.
Old Mar 31, 2011 | 11:44 PM
281-318magnum
Ok Thanks. Most likely going to get it next week, going to do try and do my first write up when i get to installing it, but I"m working 7 days 12 hours. So lets see when I get around to all this.
Old Apr 1, 2011 | 12:02 AM
97tn4x4's Avatar
97tn4x4
I know about workin those hours, SUCKS. I look forward to seeing it done, good luck.
Old Apr 1, 2011 | 12:06 AM
RamSport97's Avatar
RamSport97
Yikes, 4/6 is a fairly big drop, you are C-Knotching the frame correct?
2/4 drop would be much more effective and you could still use the truck as a truck when need be. Not to mention the wheels wouldn't rub, as long as you didn't go wider than a 275 tire.
Old Apr 1, 2011 | 12:10 AM
redheadhunter21's Avatar
redheadhunter21
Yeah dont see the srt rims and a 4/6 working, stick to a 2/4
Old Apr 1, 2011 | 12:13 AM
RamSport97's Avatar
RamSport97
Agreed.
Old Apr 1, 2011 | 12:16 AM
97tn4x4's Avatar
97tn4x4
Stock tires are what 30"? A 22 with 255 35 22 is about the same, there's more than 4" of fender gap and our wheel wells are deep. I don't see any reason why it won't work. I used to only drive lowered trucks, I'll do some measuring in the morning.
Old Apr 1, 2011 | 12:20 AM
RamSport97's Avatar
RamSport97
They will probably tuck up in there nicely and ride fine. But even stock size tires on a 4/6 dropped ram will probably rub quite violently at full lock. Especially since the srt 10 wheels are a 9 to 10" wide wheel. They will require a fairly wide tire. Not my truck though, so worth a shot I guess. I only have a 2" drop in the front and my 275/60/17's which are exactly 30", just barely rub at full lock. If it were 2" lower than it is now I know those plastic wheel liners would have been trashed by now.
Just my $.02
Old Apr 1, 2011 | 12:22 AM
97tn4x4's Avatar
97tn4x4
Check out some of these posts. I drive my 90 Mazda b2200 with a 5/7 drop with my 4 wheeler in the back sometimes. A lowered truck still has a bed lol.
