Rear differential clunking when shifting gears
Old Apr 3, 2011 | 04:05 AM
Seth_787446's Avatar
Seth_787446
Default Rear differential clunking when shifting gears
My 98 Ram has 191,000 miles and when I shift through my gears P R D doesnt matter which order, there is this really loud clunking sound coming from the rear differential. My u-joints are fine, but I took it to a mechanic and he put all new master bearing set, clutch kit, axle seals and bearings in it. Any help would be much appreciated. I made a video so you can check it out to get a better idea of what it's doing.
http://www.youtube.com/watch?v=LEHn8-9exnA
Old Apr 3, 2011 | 09:42 AM
DukesOfHazzard's Avatar
DukesOfHazzard
did he rebuild the rear end with new diff bearings ,pinion bearing? Just when it goes in gear? or shifts down the road also? Just throwing it out there seems like your backlash is out of spec http://www.youtube.com/watch?v=lO2HuZH26iA
http://www.youtube.com/watch?v=KxIpXVMMrM8
Old Apr 3, 2011 | 09:46 AM
There seems to be an awful lot of slop there...... and this is after the rebuild? I would be looking real hard at backlash, I think it is set to wide, so, too much slop between the pinion, and ring gear.
Old Apr 3, 2011 | 10:44 AM
Seth_787446
When I am coming to a stop it clunks really bad and when I take off it clunks again. He said that he rebuilt the rear differential 9 1/4 trac lock 3.90 ratio. I paid a lot of money for this to get fixed and it does the exact same thing as when I brought it there. I am going to be taking it back.
Old Apr 3, 2011 | 11:07 AM
DukesOfHazzard
i;m still debating doing mine or paying a rearend and driveline specific shop the $225 bucks they want to install my locker, theres alot to get wrong , crush sleeve for pinion , bearing preload, and backlash, let us know what they say
