lift and gear questions 98 ram???
Old Apr 5, 2011 | 01:39 AM
pashtrd's Avatar
pashtrd
Originally Posted by rl99dram
Lift is from Rough Country and I run 60-65 at about 2G maybe 2300. But with my 35s and new gears im about 4-6 mph off so 60 is 70 and so on. And my MPG is better in town and my shift points are much stronger and firmer. Runs good man.
I also have 35's and 4.88's. i am running 60 mph at 2000 rpm. 65 is 2150rpm. gas mileage seems to be better, maybe its all perspective? But i know the trans no longer hunts between 3rd and OD doing 55-65mph. That HAS to be saving gas and $$. before I was running 60 mph at 1500 rpm. trans downshifting into 3rd everytime i even thought about touching the gas.
Old Apr 5, 2011 | 12:50 PM
rl99dram's Avatar
rl99dram
What he said is very correct
Old Apr 7, 2011 | 10:04 PM
jmccallie98ram's Avatar
jmccallie98ram
so 488s, anybody runnin anything different? just want to know the pros and cons before i order my gears... thanks
Old Apr 7, 2011 | 10:12 PM
rl99dram's Avatar
rl99dram
There are no cons on 4.88s haha.
Old Apr 7, 2011 | 10:16 PM
Unka-Boo's Avatar
Unka-Boo
What size tire are you planning on running? That should determine what gear ratio you chose...
Try this calculator: http://www.4lo.com/calc/geartire.htm
Plug in the truck's stock tire size ( in inches ), new tire size and current gear ratio.
It will calculate the "effective" ratio, the recommended ratio ( middle, basically to match the "factory" gearing with the taller tires) and a number for "steeper" gears...
Old Apr 8, 2011 | 05:02 AM
97tn4x4's Avatar
97tn4x4
The only company who makes a 6" lift for our trucks is fabtech. There long arm kit is a 6" but everybody elses lift is 5". If you want a good ride I'd say drop the money and get a set of long arms.
Old Oct 26, 2011 | 02:01 PM
another tranny's Avatar
another tranny
Are you using the 4.88's in the rear(9.25) and front(D44), is there any fabbing entailed on the install?
Old Oct 26, 2011 | 10:03 PM
99dodge318's Avatar
99dodge318
If your really gonna be abusing your truck I would look for some d60's before you drop all that coin on gears.
Your factory axles are gonna need alot of service with 35's, I know im in the middle of replacing everthing the tures have worn out.
And im clearing 35's with only a $60 coil spacer, no rub either.
Old Oct 28, 2011 | 01:19 AM
Wombat Ranger's Avatar
Wombat Ranger
Dick Cepek makes a 6" long arm kit.
When i get to the point of lifting my 95 I will either be running superlift's 5" with 37's, or i will build a custom 8" longarm and run 40's.
