Confused- Help Please :/
Old Apr 3, 2011 | 09:17 PM
rl99dram's Avatar
rl99dram
Question Confused- Help Please :/
OK... is this a possible combo?
fastman TB (50 or 90 mm)
Hughs Air Gap
Kegger
and new plenum can you do all of those or is one the same as the other?? sorry for the dumb question and yes I tried the search but no luck.. Help would be fantastic and the best option thanks guys I really apprectiate it
so does my bank account
Old Apr 3, 2011 | 09:19 PM
97Rampowerhouse's Avatar
97Rampowerhouse
Kegger is just grinding down the stock manifold runners. with a air gap you wont need to worry about plenum fix.
Old Apr 3, 2011 | 09:23 PM
Mad_Scientist's Avatar
Mad_Scientist
The airgap and kegger are 2 iterations of the same thing: the intake manifold
So to answer your question: no, you cant have all of those on at the same time.
If you put the airgap intake, there is no need for a plenum repair, as the airgap is a solid 1-piece manifold.
Also, 90mm throttlebody? Where did you dream that up?
Old Apr 3, 2011 | 09:24 PM
rl99dram's Avatar
rl99dram
So that knocks the kegger and plenum fix outta the question? and isnt the fastman Throttle body like the air gap, or are they not both trottle bodys?
Old Apr 3, 2011 | 09:26 PM
rl99dram's Avatar
rl99dram
Ok so if you plenum is like destroyed and filled with garbage and oil and junk the air gap automatically fixs that? and idk i thought i saw it somewhere, sorry haha and sorry for the questions
Old Apr 3, 2011 | 09:27 PM
Mad_Scientist
No, the hughes airgap is an intake manifold (the thing the throttle body sits on), fastman 50mm is a throttle body
Old Apr 3, 2011 | 09:29 PM
97Rampowerhouse
the air gap is just a replacement manifold that increases power and eliminates the plenum. If keeping your stock manifold you will need to replace the plenum gasket with a hughes plenum plate
Old Apr 3, 2011 | 09:31 PM
ghost4321's Avatar
ghost4321
The air gap is an intake manifold, what the TB bolts to.
Old Apr 3, 2011 | 09:34 PM
Mad_Scientist
Ok, to put this in the simplest terms:
Kegger=stock intake manifold.
Hughes airgap= aftermarket performance intake manifold.
Plenum=slang referring to plenum gasket
Kegger is made in 2 peices, with the plenum gasket between them. When the gasket blows, chaos ensues (oil consumption, clogged cat, etc.).
Hughes airgap is one peice, and therefore, has no plenum gasket, so it cannot blow out (because it doesnt exist).
Hope that clears it up.
While we're on the subject, continue posting terms that a new user/mechanic may not know, and I will answer to the best of my ability.
Ex. TB=Throttle body, IAC=Idle air control motor, etc.
Old Apr 3, 2011 | 10:06 PM
rl99dram's Avatar
rl99dram
Ok gotchya really appreciate it haha, so the combo im lookin at here is an Airgap followed up by a Fastman 50mm TB and upon that is a 14X3 ... sound sexy? lol and have you guys heard of 1.7 rockers any intel on that?
