A/C Clutch Fuse Keeps Blowing
Old Apr 3, 2011 | 09:50 PM
travismc's Avatar
travismc
Default A/C Clutch Fuse Keeps Blowing
99 1500...A/C was running great, blowing cold then one day stopped blowing cold. Checked the relay and relay was fine, then checked the fuse for the a/c clutch and noticed it was blown.
Replaced the fuse and everything ran fine, blew cold...then the next day stopped blowing cold again. Checked and the fuse was blown again. Now everytime I replace the fuse it immediately pops the fuse.
Don't want to have to replace the entire compressor if it runs fine...can I just replace the clutch? Or do I have another problem?
Thanks for the help!
Old Apr 3, 2011 | 09:54 PM
Mad_Scientist's Avatar
Mad_Scientist
Sounds like you got yourself a short-to-ground somewhere after the fuse but before the a/c clutch. You're going to need a volt meter, a 6-pack, and a dog that doesnt mind being cussed at.
Old Apr 3, 2011 | 10:16 PM
travismc's Avatar
travismc
Fun...any tips on chasing the short???
Old Apr 3, 2011 | 10:44 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Unplug the wire to the clutch and replace the fuse. If the fuse doesn't blow the rest of your wiring is ok. Now plug the clutch wire back in, if it blows the clutch is shorted.
Old Apr 4, 2011 | 09:53 AM
travismc's Avatar
travismc
Ok...unplugged the connector at the clutch and the fuse did NOT blow. Plugged it back in and the fuse blew.
So either the clutch is shorted or the wire from the connector to the clutch is shorting to ground??
Suggestions on next steps???
Old Apr 4, 2011 | 10:21 AM
Check resistance across the terminals on the A/C clutch. I think 5 ohms is correct? If you get zero..... replace the clutch.
Old Apr 4, 2011 | 11:26 AM
travismc's Avatar
travismc
No resistance at the clutch.
Next question...where can I find a clutch? I see the bearings and removal tools online but I can't seem to find the clutch plate itself???
Old Apr 4, 2011 | 11:32 AM
Comes as an assembly I do believe. Should be able to get one from advance, or napa, or whomever your favorite local auto parts store is.
Old Apr 4, 2011 | 11:41 AM
travismc's Avatar
travismc
That's the problem...the only thing I can find is a clutch bearing on autozone's site but I did find this on ebay...
http://cgi.ebay.com/ebaymotors/1994-...Q5fAccessories
Would that work?
Old Apr 4, 2011 | 12:14 PM
Looks like it, maybe..... Might wanna call your local parts store, and ask 'em if they have/can get what you need.
