Feels like rubble strip when I touch the brakes
Old Apr 4, 2011 | 08:35 PM
Beachbum3478's Avatar
Beachbum3478
Default Feels like rubble strip when I touch the brakes
I have a 96 ram 1500 ext 5.2 4x4. I installed a 2 inch lift (coil spacers and rear blocks) and new brakes and rotors. Now when I first touch the brakes, i feel like a quick vibration through the pedel from the front left wheel area. It feels like i hit a rumble strip real quick, but not as violent. It only happens in the first 25% of the pedel travel. It wont do it if i push the pedel down fast though. Any ideas where to start looking?
Old Apr 4, 2011 | 08:43 PM
ryan0714's Avatar
ryan0714
sounds kinda like you might have a little air in the system, id start simple first, did you bleed them good? just a thought.
Old Apr 4, 2011 | 08:45 PM
mike.97.2500's Avatar
mike.97.2500
also i dont know if your truck came with abs but i do know your supposed to bleed them with a scantool to actually activate the abs to get the air out
Old Apr 4, 2011 | 09:06 PM
Gerehead8's Avatar
Gerehead8
Sounds more like a warped rotor to me. Air in the system just make the pedal soft, unless it is causing trouble with the ABS then I am not sure.
My '96 parts truck only has rear abs.
Old Apr 4, 2011 | 09:32 PM
Silver_Dodge's Avatar
Silver_Dodge
My moneys on the rotor.
Old Apr 5, 2011 | 12:07 PM
Beachbum3478
No abs on my truck. What are the chances a new rotor is faulty? Besides the motor and tranny, the truck has 212,000. Can a bearing be going bad? or u joint?
Old Apr 5, 2011 | 12:45 PM
Ram_King's Avatar
Ram_King
the chances of a rotor coming warped could be because of the cheap japan metal they use anymore, check bearings, i had the same problem, also, i would check and replace the front u joints also, i have a 97 with 228,000 and i had the same problem and just replaced anything that could have been making my truck shake.
Old Apr 5, 2011 | 12:46 PM
If you only feel the vibration when you step on the brakes...... that would tend to point at the brakes. Was the vibration there before you did the brakes?
I have had far too many "new" rotors have a bit of a warp to them simply from sitting on the shelf. As a matter of policy, I always put 'em on the lathe, and shave a couple tenths before installing them.
