rims from a 3rd gen
Old Apr 5, 2011 | 01:46 AM
RockGuardedDak's Avatar
RockGuardedDak
Default rims from a 3rd gen
I have a buddy that just bought a set of 20's off of a 3rd gen ram. the tire size 275/60/R20. His truck is a 1999 2WD. will the rims and tires will fit on the truck without any modifications? If not, what modifications will need to be done to make them fit?
Old Apr 5, 2011 | 11:19 AM
matty675's Avatar
matty675
my 4th gens fit no problem. they should bolt right up, same lug pattern and everything.
Old Apr 5, 2011 | 03:08 PM
PurplDodge's Avatar
PurplDodge
Not on a 1994-99 2WD. The holes on the wheel that go over the hub has to be modified.
Old Apr 5, 2011 | 06:06 PM
RamSport97's Avatar
RamSport97
+1. The center hubs have to be bored out a little in order to fit around the bearing dust caps. If you do this make sure to get a nice silver or chrome paint to paint the dust caps with, as you won't be able to use the center caps for the wheels.
Old Apr 6, 2011 | 05:48 AM
96magnumram's Avatar
96magnumram
take a peek here....
http://semopars.com/showthread.php?t=1110
Old Apr 6, 2011 | 02:07 PM
RockGuardedDak
ok, thank you very much. i guess its just a matter of shaving either the rim down, or the hub. i will let you guys know how it went if he gets them on
EDIT: will a 4x4 hub/rotor assembly fit onto a 2wd in order to try and make the rims fit? just a shot in the dark
Old Apr 7, 2011 | 01:36 AM
matty675's Avatar
matty675
not at all
Old Apr 7, 2011 | 02:38 AM
TryMeImHard's Avatar
TryMeImHard
you could take dust cap off and pack that F'er with grease prob solved
Old Oct 2, 2011 | 10:09 PM
RockGuardedDak
I actually forgot that I was looking into this for him LOL. Well, he ended up buying a ****fire off me to use as his DD and parked the truck at his parents. He sold those rims to a buddy cause he couldnt be bothered to do anything with them. His loss
