A/C Blows Warm Air When Stopping Suddening
Old Apr 7, 2011 | 11:55 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I know how to "How to help prevent brake dust build-up"
Old Apr 7, 2011 | 11:56 AM
MagnumVP's Avatar
MagnumVP
"How to help prevent brake dust build-up"?? Don't use brakes or use only ones made of titanium.
Old Apr 7, 2011 | 11:58 AM
zman17's Avatar
zman17
I also know how to keep your wheels clean for up to 4 weeks.
Old Apr 7, 2011 | 11:59 AM
MagnumVP's Avatar
MagnumVP
If you get black wheels, then they are clean of brake dust year round.
Old Apr 7, 2011 | 12:33 PM
MagnumVP's Avatar
MagnumVP
I've used my 4x4 since the change, but can't remember if I have used the cruise. I will test it on my way home today.
Old Apr 7, 2011 | 12:48 PM
zman17's Avatar
zman17
A vac leak or this can cause your problem depending on what Dodge put in it. A 99 could go either way. https://dodgeforum.com/forum/2nd-gen...-door-fix.html
Old Apr 7, 2011 | 12:56 PM
MagnumVP's Avatar
MagnumVP
Well I decided that I couldn't wait so I took the truck for a little spin. The Cruise Control does NOT work either.
Old Apr 7, 2011 | 12:59 PM
zman17's Avatar
zman17
Check the vac lines. The CC motor is under the battery and the vac line is prone to cracking/rotting due to the acid from the battery.
Old Apr 7, 2011 | 01:01 PM
MagnumVP's Avatar
MagnumVP
Is there anything in particular that I should be looking for when checking the vac lines? If I don't see any physical damage to the lines, how can I test them?
Old Apr 7, 2011 | 01:09 PM
zman17's Avatar
zman17
Read the link I posted. The lines could be fine, but the check valves could be bad. The control panel on the dash could be bad too, but only you can determine that.
