o2 sensor ?
Old Apr 7, 2011 | 08:22 PM
cooper69's Avatar
cooper69
Default o2 sensor ?
I need to change both o2 sensors on my truck but can't get them to crack loose. Any idea's as to how I get these things out?
Old Apr 7, 2011 | 08:30 PM
rl99dram's Avatar
rl99dram
PB blaster let soak, beat the crap out of'em or just cut the peace of pipe off.
Old Apr 7, 2011 | 08:31 PM
Got heat? Warm 'em with a torch. Or, drown them with chemicals. A tight wrench, and breaker bar works fairly well too.
Why are you replacing the rear O2?
Old Apr 7, 2011 | 08:42 PM
redneck_ram's Avatar
redneck_ram
cut the wires off put a box wrench on it and then slide the box end of another wrench over the open end of the wrench on the o2 sensor and yank! should loosen with ease! i had no problems at all taking mine out and i live in new england where they over salt the roads in the winter!
Old Apr 7, 2011 | 09:26 PM
cooper69's Avatar
cooper69
I'm replacing them cuz the truck has 162,000 miles and I'm pretty sure they are originals. Plus the truck just seems very drowgy at times and the shop i go to told me they were bad (engine light).
What's PB blaster?
Old Apr 7, 2011 | 09:27 PM
redneck_ram
pb blaster is by far the best rust penatrant on the market!
Old Apr 7, 2011 | 09:34 PM
PurplDodge's Avatar
PurplDodge
What's PB blaster?
The rear 02 sensor just checks to see if the catalytic converter is working. It doesnt affect performance. Just change the front one with a NTK or Denso sensor.
PB Blaster or Aero Kroil, heat, and a large cheater bar.
Old Apr 7, 2011 | 09:43 PM
redheadhunter21's Avatar
redheadhunter21
Drive the truck get exhaust nice and hot then spray some lubricant and hop under there with a nice size adjustable(i used an 18") and it should come right out
Old Apr 7, 2011 | 10:09 PM
rl99dram's Avatar
rl99dram
Thats the stuff I used to take out the rust on my truck when I was puttin lift on, good stuff man. If you take out front sensor you have better flow? I cut my pipe off behind cat then got flex pipe and bend it down as weekend warrior but put'er back on when it gets annoying haha. Irrelevent but I thought id say lol.
Old Apr 8, 2011 | 01:21 AM
UnregisteredUser's Avatar
UnregisteredUser
Haven't tried CRC Freeze-Off yet, huh?
