Help truck wont start
check fuses in the end of the dash and under the hood in the power box. you might have shorted a seat belt wire or speaker or amp or something. check the odd ones labeled IOD and the main fusible link thingy.
also - check fuse for fuel pump, and listen for the initial whine when ignition is first turned on.
if no help, then check engine for spark at the plugs.
check for fuel pressure by depressing the test valve in the rail. caution - do not smoke and hold a rag over it or it'll squirt directly into your eyeball.
LMAO no I didnt power was the interior. But I am gonna break out the pressure washer Sunday and do some cleaning.
