Factory amp
Old Apr 8, 2011 | 09:08 PM
dan64779's Avatar
dan64779
Cool Factory amp
can anyone tell me where the factory amp is in my 98 ram 1500?
Old Apr 8, 2011 | 10:53 PM
jasonw's Avatar
jasonw
Site Moderator
Moved this to its own thread for you, since its a completely different topic from your other thread.
The factory "amp" on the Infinity equipped trucks are two small amps, one on each front door speaker. If not Infinity speaker or stereo equipped, you don't really have an amp other than the basic one built into the head unit.
Old Apr 8, 2011 | 11:45 PM
TryMeImHard's Avatar
TryMeImHard
correct they are on speakers that is why there are 4 wires to each speaker
Old Apr 9, 2011 | 01:48 AM
redheadhunter21's Avatar
redheadhunter21
there is also amps on the rear speakers
Old Apr 9, 2011 | 12:17 PM
dan64779's Avatar
dan64779
thank you guys for the info. i tryed putting in an alpine headunit but only 1 speaker worked so i put the factory deck back in. so i guess im going to have to buy new speakers and run new wire for them.
Old Apr 9, 2011 | 12:42 PM
Mad_Scientist's Avatar
Mad_Scientist
If memory serves, you can use the same wire, but only 2 of the 4... as to which 2... can't say, been a while since I did it.
Old Apr 9, 2011 | 12:59 PM
97tn4x4's Avatar
97tn4x4
http://www.the12volt.com/installbay/vehicles.html
Follow that link and put in your vehicle info and it'll tell you what color wires you use.
Old Apr 9, 2011 | 01:07 PM
redheadhunter21
On my 96 I used the 2 inside wires, take a test light and hit each wire, you will have a power, 2 signal wires and a ground. You want to use the signal wires and tape off the power and ground, the signal wires will just barely light up a test light, and be easy to spot out
Old Apr 10, 2011 | 08:46 PM
dan64779's Avatar
dan64779
ok thank you. ill try those wires and see what they do.
Old Apr 20, 2011 | 11:17 PM
gipperkid's Avatar
gipperkid
Just an FYI for Infinity. Like 94-97 Rams had 4 wire speakers, 98-99 had 6-wire speakers, and 00-02 had like 8- or 9- wire speakers. I just had to change one in my 2000 Ram. I was shocked at how many wires were on the connector. I will post a pic of it tomorrow.
