Body lift is DONE!!! But a few problems after
Old Apr 11, 2011 | 03:33 PM
awramit's Avatar
awramit
Originally Posted by zje400ex
When i disconnected my battery, my idle did some crazy things. It would start up fine, but when I got on the throttle then let off...my truck would die
That the same problem I am having. I have driven maybe around 100 miles so far and it still wont idle. I just keep my foot on the pedal the whole time.
Old Apr 11, 2011 | 05:24 PM
dodgeram07's Avatar
dodgeram07
you check the IAC? it on the back of the TB, check the wires going to it
Old Apr 12, 2011 | 12:07 AM
awramit's Avatar
awramit
UPDATE!!!
Ok went out today to work on it and VROOM!! started right up and runs no problem :-)
Thanks for all your help guys. Must have just taken a long time to reset the idle.
Old Dec 30, 2014 | 03:01 AM
projectcodered1's Avatar
projectcodered1
I did my 3" body lift and used the 3" extension for the trans shift linkage now it won't fit but when I took it off this now to short what do I do?
Old Dec 30, 2014 | 01:19 PM
The linkage is adjustable...... start there.
Old Dec 30, 2014 | 07:05 PM
projectcodered1
I believe its cause the guy I had reweld the extension in has it backwards of what it should be. But also is it necessary for the steering extension? It looks fine to me.
Old Dec 31, 2014 | 11:06 AM
If they give it to you in the kit, I would install it. You don't want to find out that Yes, it IS necessary, by having your steering shaft fall apart while driving. That would most certainly be a pants-filling moment.
Old Dec 31, 2014 | 03:21 PM
merc225hp's Avatar
merc225hp
^^^ +1
