318ci, 360ci whats the difference?
Old Apr 13, 2011 | 10:40 PM
alfonsmax's Avatar
alfonsmax
i dont think it was upgraded to the 5.9 because its still reading 5.2 with the scanner, do you know what i can do for it to read or recognize that it has a 5.9?
thanks
Old Apr 13, 2011 | 10:43 PM
Gerehead8's Avatar
Gerehead8
thanks
Pull a plug, look inside the combustion chamber and try to see the dished part of the piston. I could see it with my engine on the stand so it is possible.
Old Apr 13, 2011 | 10:49 PM
thanks
First, you have to make damn sure you actually have the 5.9. If you do, need to reflash the PCM for the larger motor. Hemifever could prolly set you up.
Old Apr 13, 2011 | 10:56 PM
Mad_Scientist's Avatar
Mad_Scientist
Here ya go: http://www.ehow.com/how_7706969_identify-chrysler-la-magnum-engine.html#ixzz1CHXCdQ6u
Might be easier to do what gerehead said if you cant find the casting number (still looking for mine)
Old Apr 13, 2011 | 11:03 PM
rl99dram's Avatar
rl99dram
This explains why my 318 cant roast off 35 inch tires but my buddy can, 360... same lift same truck same year, model etc. Different engines. lol
Old Apr 13, 2011 | 11:23 PM
alfonsmax's Avatar
alfonsmax
awesome, thank you. found casting number, and yes i have a 5.9, now just gotta look for the date, on the other side of block. too dark to do it know, fellas thanks again for info, i contacted hemifever see if they can help me with the computer. if not i wonder if i can buy a 5.9 engine computer and just plug into mine, does anyone know if it would work?
Old Apr 13, 2011 | 11:26 PM
Gerehead8's Avatar
Gerehead8
Yeah a 5.9L computer is a direct replacement for your 5.2 computer.
Year doesn't really matter on Magnums. They are pretty much all the same.
Old Apr 13, 2011 | 11:27 PM
97tn4x4's Avatar
97tn4x4
Yep that's all you need to do. Bit the programmer would be nice.
Old Apr 13, 2011 | 11:52 PM
95RAM360's Avatar
95RAM360
its very easy to tell if its a 5.9 or 5.2....just look at the crank pulley....if it is only the pulley its a 5.2, but if theres another ring behind the pulley its the 5.9
Old Apr 13, 2011 | 11:56 PM
Mad_Scientist
Dunno about that, the ECT set up is different. Not sure if it matters, but I think if he got a newer one (or older depending on his year) it could be looking for temp input on a different pin.
I.E. if he gets a PCM that is looking for 2 sensors for temp (ect and sending unit 94-96 models I think) and his truck is set up with the one sensor (97+ I believe) it could cause issues if the programming is looking for that info to come in from a different doorway.
I'd flash it to be safe, or get one that is from around the same year. Any 94-96 is interchangeable and 97+ for the rest.... if that makes any sense
