318ci, 360ci whats the difference?
Old Apr 14, 2011 | 12:03 AM
  #21
Gerehead8's Avatar
Gerehead8
Originally Posted by 95RAM360
its very easy to tell if its a 5.9 or 5.2....just look at the crank pulley....if it is only the pulley its a 5.2, but if theres another ring behind the pulley its the 5.9
Not true. The 5.2L still has a balancer it isn't just a pulley. The 5.9L balancer will have a notch out of it for the external balance.
Originally Posted by Mad_Scientist
Dunno about that, the ECT set up is different. Not sure if it matters, but I think if he got a newer one (or older depending on his year) it could be looking for temp input on a different pin.
I.E. if he gets a PCM that is looking for 2 sensors for temp (ect and sending unit 94-96 models I think) and his truck is set up with the one sensor (97+ I believe) it could cause issues if the programming is looking for that info to come in from a different doorway.
I'd flash it to be safe, or get one that is from around the same year. Any 94-96 is interchangeable and 97+ for the rest.... if that makes any sense
I guess I didn't specify. He must get another 96 computer. No other computer will work as 96 was a transition year.
94-95 is interchangeable as they are OBD I. 96 is all by itself, 97 may be too. Not sure on the others but 99-01 are probably interchangeable as they didn't change much in those years.
Old Apr 14, 2011 | 12:04 AM
  #22
95RAM360's Avatar
95RAM360
well thats weird because my dad had a 5.2 and it was only the pulley where the belt rolls on, and didnt have anything else...
Old Apr 14, 2011 | 12:20 AM
  #23
Gerehead8's Avatar
Gerehead8
Was the balancer and pulley cast as one?
Old Apr 14, 2011 | 12:43 PM
  #24
97tn4x4's Avatar
97tn4x4
My 97 has 2 temp sensors
