overheating and radiator under vacuum?
Old Apr 13, 2011 | 06:50 PM
  #31
Shouldn't be coolant. No easy way for it to get in there. if it was coolant/oil, it would be kinda milky looking. If you are getting pooling of what appears to be oil, time to do the plenum.
Old Apr 13, 2011 | 06:51 PM
  #32
Mad_Scientist's Avatar
Mad_Scientist
Originally Posted by sullivanj04
so replaced t stat looked like the original based on the gasket so ill check it soon as the rtv dries. decided to check the plenum wile i had the air box off and well......dont think its good. it looked like 1/16 inch of liquid maybe oil maybe coolant or a mix it seemed to clean to be all oil based on how badly it needs it changed so is it possible it could be coolant?
Not unless you blew a head gasket or cracked the block somewhere.... You'd know if you did either..... It's probably just oil. You'll wanna look into changing the plenum to avoid more serious issues down the line.
EDIT: I swear heyyou, you must have some form of dodgeforum specific ESP lol. Ninja'ed once again
Old Apr 13, 2011 | 06:57 PM
  #33
sullivanj04's Avatar
sullivanj04
thanks for your help i dont thing the head gasket is blown doesnt smoke so i guess its plenum time, does any one else sell aftermarket intake manifolds to fix the plenum problem, would like to go that rout but dont want to spend $600 on one
Old Apr 13, 2011 | 07:03 PM
  #34
Mad_Scientist
The airgap is the only one I know of... and that is the $600 on in question.
Just do the plenum gasket and replace the plate with aluminum. Using an aluminum plate and shorter bolts in place of the OEM stamped steel plate *******ly guarantees against any future failures.
EDIT: ummm.... yeah, I'm not sure why the word "v-i-r-t-u-a-l-l-y" is being screened, but last time I checked, it wasn't a cuss word... where is a mod to correct this?
Old Apr 14, 2011 | 05:30 PM
  #35
sullivanj04
so new t stat is in and that fixed the problem
Old Apr 14, 2011 | 06:09 PM
  #36
That's bizarre.
Old Apr 14, 2011 | 11:08 PM
  #37
sullivanj04
didnt fix the plenum issue sorry should have clarified it fixed the overheating issue
Old Apr 15, 2011 | 07:52 AM
  #38
Novarider's Avatar
Novarider
Maybe it just got burped correctly after he replaced the tstat?
Old Apr 15, 2011 | 11:34 PM
  #39
ghost4321's Avatar
ghost4321
I guarantee the old t-sat won't open if he puts it in boiling water.
Old Apr 16, 2011 | 02:07 AM
  #40
TryMeImHard's Avatar
TryMeImHard
well i apologize for arguing the fact that it was running backwards
